Capturing DV footage from a Z1 to Final Cut
Jason Macalpine
on Feb 7, 2010 at 7:23:19 am
Hey guys,
I am having a lot of trouble capturing footage from my Z1 into FCP...
Can someone please help me with the settings for my camera and FCP?
Thanks so much in advance!
John Fishback
Re: Capturing DV footage from a Z1 to Final Cut
on Feb 7, 2010 at 4:45:06 pm
Here's an excellent tutorial explaining how to capture HDV to ProRes over FW. Simply adapt it to DV. You need only change a few settings to DV and it should work. If you need step-by-step instructions, search the Cow I'm sure you'll find the exact workflow you need.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
