Final Cut Compositings to Color?
Univers Becker
on Feb 5, 2010 at 9:35:06 am
Hello,
I want to send a to layer compositing from Final Cut Pro to Color. But I get always a two layer colorproject, but I want to Color the finish compositing at once, not the single layers at self. Than I group the Layers in Final Cut in to a sub-sequence (now it is only one layer), but it doesn't helped. Any Idears??
Greetz Univers
Rafael Amador
Re: Final Cut Compositings to Color?
on Feb 5, 2010 at 12:55:47 pm
So export a movie and import to Color.
Rafael
http://www.nagavideo.com
Shane Ross
on Feb 5, 2010 at 6:18:30 pm
If you send two video layers to COLOR, it sees both layers. It doesn't finish the composite for you. If you want the composite as one single video, DO NOT NEST. Color doesn't do nests. Do what Raf suggests...export a self contained QT movie, and reimport.
Shane
