Trying to print to tape, only audio
Quintin Lundy
on Feb 1, 2010 at 2:25:10 am
I am trying to print my HD project to dvcam tape. Is this possible? I've tried to print to tape in final cut, but it only records the audio and the rest is black. Should i change my settings? Can I use mini dv instead? What is the best way to transfer my project to dv tape?
Rafael Amador
Re: Trying to print to tape, only audio
on Feb 1, 2010 at 3:08:43 am
Hi Quintin,
First you need to convert your movie to DV.
Drop your HD movie in a DV sequence, set "Render in High Precision" an "Render Motion Effects: BEST".
When rendered you can print it o DV or DVCam.
rafael
http://www.nagavideo.com
Quintin Lundy
on Feb 2, 2010 at 5:04:59 am
Thanks alot I'll try it out ASAP
