what setting in FCP 6 to import hdx 900 footage shot at 24p
frederic menou
on Jan 27, 2010 at 3:50:15 am
Hello all,
I shot some footage with the panasonic hdx 900 at 1080 24p (not 24pa) and want to import it in FCP 6 using firewire and the panasonic deck.
Simple question: what setting should I use in FCP for the import?
I don't see the 1080p 24?
(Also I want to cut that footage with some that I shot with the varicam at 720 24p. So I want the frame rate to match...)
Thanks for your help
Rob Grauert
Re: what setting in FCP 6 to import hdx 900 footage shot at 24p
on Jan 27, 2010 at 1:16:49 pm
I believe 24p has pulldown added to make it 60i. Therefore, you'd capture 1080i60.
Robert J. Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com
