Need sequence setting guidance
Roli Rivelino
on Jan 25, 2010 at 4:28:28 pm
I record clips on my Panasonic HVX onto my FS-100, my camera is set to video cam and I'm recording at 720p 25 on my FS-100 I'm set to DVCPRO.
So what I'm wondering is, why my QT compressor settings, inside my sequence settings are set to DVCPRO HD 720p50 and why I see 50 frames in a second instead of 25?
I know this is really basic stuff, but I wasn't paying attention earlier!
Many thanks for your help.
aka Newbie Wan Kenewbie. "The young Newbie, is now a Padawon."
System
Mac Pro 2.8Gb quad core
8Gb RAM
1x 320Gb 7200 hardrive
1x 1Tb 7200 hardrive
Nvidia Geforce 8800 512mb Graphics card
1x 1Tb external WD 'My Book' eSata
Equipment
Panasonic AG-HVX 200
Firestore FS-100
Shane Ross
Re: Need sequence setting guidance
on Jan 25, 2010 at 5:18:03 pm
720p is a 50 frame (or 60 frame in NTSC land) format. Unless you chose 25pN, your footage will be 50 frames per second.
Shane
Roli Rivelino
on Jan 25, 2010 at 7:55:49 pm
aha I see, thanks Shane, is there any advantage/disadvantage using 720p over PN?
System
8Gb RAM
Equipment
Firestore FS-100
Shane Ross
on Jan 25, 2010 at 8:17:55 pm
[Roli Rivelino] " is there any advantage/disadvantage using 720p over PN? "
Saves space. Allows for you to shoot great slow motion at 720p60. And if you deliver DVDs, or masters that are 23.98 than it is great. And having a Capture card that will add the proper pulldown when you output helps with the conversion too.
Shane
Roli Rivelino
on Jan 25, 2010 at 9:21:32 pm
You've enlightened me once again, many thanks Shane.
System
8Gb RAM
Equipment
Firestore FS-100
