How to select the best sequence for the footage
Rob Jansen
on Jan 20, 2010 at 4:24:25 pm
Hi everyone,
I would really like to have some advise on how to setup my sequence.
So far i only worked with just DV PAL, but now that i'm working with different files, i just want to be sure i'm not forgetting any settings in the setup.
I have a bmp-sequence in an avi-container.
1108x824
24fps
62,7 Mb/sec
pixel aspect: square
Field dominance: none
For aspect ratio should i pick CCIR 601 PAL Sq. (4:3)?
And what to use in the QuickTime Video Settings bar?
I need to keep the best quality of the image.
Thanks, Rob
Rafael Amador
Re: How to select the best sequence for the footage
on Jan 20, 2010 at 6:50:07 pm
Hi Rob,
What gonna be your final delivery format?
Web, DVD, DV Tape?
rafael
http://www.nagavideo.com
Rob Jansen
on Jan 20, 2010 at 9:39:33 pm
Hi Rafael,
thanks for your help.
The final delivery format is that it will be printed on 35 mm.
Rob
Bruna Abubakir
on Feb 3, 2010 at 6:11:26 pm
Rob,
Are you editing an offline telecine? Or is it video transfer to film? If it is an offline telecine then use the sequence exactly matching your footage so that there are no timecode alterations, once you start messing with those numbers the lab won't be able to print correctly.
If your doing a video transfer to film, then you can use any sequence you want that will keep end result quality the same or better than the shot material.
Hope this helps.
Just a very big puzzle mister man.
