Mixed formats on timeline
Walter Miale
on Jan 4, 2010 at 11:52:23 pm
(For FCP7), is it OK to have mixed formats (eg ProRes 422sd and dv) on the same timeline? How? Do I just select the frame or frames I want to change and then assume the rest of the timeline won't change?
Rafael Amador
Re: Mixed formats on timeline
on Jan 5, 2010 at 12:59:48 am
Walter,
FC will cope well with different codecs and sizes in the same sequence, but not with stuff with different time-base.
Rafael
http://www.nagavideo.com
Walter Miale
on Jan 5, 2010 at 2:07:04 am
I see, thank you.
BTW Rafael, your videos are magnificent, as you well know. I'm watching them over and have to pry myself away.
Walter
Shane Ross
on Jan 5, 2010 at 7:46:30 am
You CAN edit mixed frame rates...FCP will play them. But not very well. Internally it doesn't add/remove pulldown properly. When it comes to frame rates, best to have uniformity.
Shane
