Log and Cupture
Jerry Luxik
Log and Cupture
on Dec 26, 2009 at 2:47:50 am
How to capture DV video to HDV project.Thank you jerry
Shane Ross
Re: Log and Cupture
on Dec 26, 2009 at 6:52:41 pm
Capture DV as DV...via firewire using the DV/NTSC Easy Setup. You cannot capture DV as HDV unless you had a capture card...but then you wouldn't want to capture DV as HDV as HDV is a very odd format, and you won't want to CONVERT anything TO that format.
Want to mix HDV and DV? Edit in a ProRes HD timeline...you will have to upscale the DV manually.
Shane
