TV playback
Sean McGuigan
TV playback
on Nov 27, 2009 at 3:22:51 pm
I need to be able to work at 24p film speed, resolution is less important. We've tried encoding HD 8bit uncompressed, DVC Pro and Apple Pro Res, all files playback on the Final Cut monitors but on the plasmas the image is not displaying correctly, I have the image cut off by 1/3 on the left hand side of the TV screen, although it does play...
Please advise!
MacPro
FCP 7
Blackmagic Decklink HD Extreme
32 inch Toshiba Plasma
Neil Sadwelkar
Re: TV playback
on Nov 30, 2009 at 2:40:15 pm
What is the resolution of the sequence?
If its HD and 24p, then the BM card should play it fine out of the HD-SDI output.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Sean McGuigan
Re: TV playback
on Dec 3, 2009 at 5:48:35 pm
Hi Neil, managed to get the output problem sorted. In the BM preference pane under settings, all that needed to be done was to activate 'use 1080p not 1080PsF' Previously we were getting the image filling only 2/3rds of the screen.
Thanks for your post
Sean
