Audio Blown Out Static Sound
SatBir Khalsa
on Aug 29, 2012 at 8:18:33 pm
Hi Guys,
I imported my files into FCP7- When I go to playback the clips the sound is all blown out and static like. When I play the same clip in Quick time out side of FC it sounds fine. Not sure what settings I need to set it at in order for this to work? Bellow is how I have my files converted from toast.
en agradecimiento
Video
Format: Quick time movie
Size: 1920 x 1080
Aspect Ratio: Automatic
Overscan: Automatic
Frame Rate: 29.97
Data Rate: Automatic
Audio
Format: Linear PCM
Sample Rate: 48000
Channels: Stereo
Mark Suszko
Re: Audio Blown Out Static Sound
on Aug 29, 2012 at 9:37:45 pm
Did you enable the audio level controls for the audio tracks and pull them down to about minus 12 DB?
