24P project to 60i (29.97) deliverable.
Steven Gladstone
on Nov 17, 2009 at 7:06:06 am
Hi, I've just shot and edited a piece shooting at 720P 24fps (really 23.976) Shoot and edit went flawless, outputted as a Quicktime 720P24fps great, same as an MP4 (h.264 codec.)
However I now have to deliver a version that can play on Broadcast T.V. Although I understand the pulldown process to convert 24 to 30 (23.976 to 29.97), I don't know what settings to use in Final Cut.
I'm on Final Cut 6.05, and have compressor 3. I'm expecting to have to go to a file for delivery, but might also have to deliver a DV tape. Any suggestions would be appreciated.
I searched through the list archive, but no luck so far.
Thanks.
Steven Gladstone
http://www.gladstonefilms.com
John Fishback
Re: 24P project to 60i (29.97) deliverable.
on Nov 17, 2009 at 8:19:36 pm
If you have a Kona or similar I/O card or device you can simply play it out in real time. The card will add the pulldown. If it has to be a file, Compressor can do it, although, not as well as the Kona. Be sure to enable Frame Controls in Compressor's Inspector and choose Best for all quality settings.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
