Help Scaling Full HD to 720p
Declan Smith
on Nov 7, 2009 at 1:32:59 am
I have raw footage that is Full HD (1920 x 1080) but is badly framed. The final project format is 1280 x 720. What I want to be able to do is drag the Full HD clip into the sequence and be able to effectively reframe it (as the source is in effect, a large size). When I drag the clip to the sequence, it first asks if I want to change the sequence (which I say No), then it displays in the canvas but it has been zoomed and cropped. I was expecting the wireframe to be larger than the image, allowing me to scale and reframe.
Any ideas?
Declan Smith
FCS3 / Combustion / Canon XL2
Rafael Amador
Re: Help Scaling Full HD to 720p
on Nov 7, 2009 at 3:54:50 am
In the FC Preferences you must check that the clips don't get resized when dropped to the sequence.
Or just select the clips in the sequence and "Remove Attributes: Basic Motion".
© 2018 All Rights Reserved
