Slugs???
Francis Robertson
Slugs???
on Oct 25, 2009 at 11:05:41 am
Hi, I have a question about slugs.
I'm not really familior with them, AVID jut treats any empty section of video track as a clip and I can apply filters and effects to them as I can with a normal clip.
I find this usefull when applying filters as transition effects, for example I can use a plugin (lets say Glow) and apply it to 8 frames on the layer above an edit and then alter the keyframes and parameters to create an interesting flash transition. I can do the same with Lens Flare and Paint and all the other effects in the pallete
I find this easier than having to apply the same effect to the last 4 and first four frames of the in-coming and out-going clips.
So I tried to do the same in FCP and it didn't let me.
Then I discovered slugs and I thought I had cracked it, but no.
I tried adjusting the opacity of the slug but that didn't work.
So what am I doing wrong? Can I apply effects in the same way as I am used to on AVID? Am I making sense?
Hope you can help.
Tom Wolsky
Re: Slugs???
on Oct 25, 2009 at 12:42:07 pm
It's not going to work the way Avid works, period. You could try applying your lens flare or whatever to a slug and using a screen composite mode on it.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP6," "Basic Training for FCS2" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
Francis Robertson
Re: Slugs???
on Oct 25, 2009 at 1:05:59 pm
Thanks, Ill try that.
