insufficient material?
Patrick Bronte
on Oct 25, 2009 at 3:44:10 am
What am I doing/not doing to get 'insufficient material to make edit' when trying to apply a transition effect?
I would really appreciate it If anyone could recommend any FCP effects training that helped them ...
Zane Barker
Re: insufficient material?
on Oct 25, 2009 at 5:32:47 am
For a transition to work there must be a little extra footage at the end of the clip you are transitioning from and also on the clip you are transitioning to.
I'll bet a million dollars you are trying to add a transition onto a clip that does not have the extra room.
There are no "technical solutions" to your "artistic problems".
Don't let technology get in the way of your creativity!
Patrick Bronte
on Oct 25, 2009 at 5:39:11 am
So when adding clips to the timeline from the viewer, you must include handles in order to apply transitions etc....?
Cant you just center a transition on the cut...?
thanks for the tip
Zane Barker
on Oct 25, 2009 at 5:42:20 am
http://www.kenstone.net/fcp_homepage/basic_transitions.html
Steven Gladstone
on Nov 17, 2009 at 7:11:17 am
I get that same error message sometimes, even though I am doing an insert edit and not an insert with transition. I can be annoying.
Steven Gladstone
http://www.gladstonefilms.com
Steven Gladstone
on Nov 17, 2009 at 7:12:01 am
I get that same error message sometimes, even though I am doing an insert edit and not an insert with transition. It can be annoying.
Steven Gladstone
