Import from Flip Ultra HD to Final Cut Pro 7
Guy Dor
on Oct 18, 2009 at 1:32:38 pm
Can I do that?
Zane Barker
Re: Import from Flip Ultra HD to Final Cut Pro 7
on Oct 18, 2009 at 3:41:01 pm
You will want to use compressor to convert the video into a proper editing format first.
There are no "technical solutions" to your "artistic problems".
Don't let technology get in the way of your creativity!
John Fishback
on Oct 18, 2009 at 3:46:32 pm
Do as Zane suggests - use Compressor. I did this a couple of weeks ago. I turned the Flip files into ProRes and the quality was surprisingly good. Be sure to turn Frame Controls On (in Compressor's Inspector) and set all quality options to Best.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
