Final Cut 6 and 7
James Tayler
Final Cut 6 and 7
on Sep 21, 2009 at 8:58:57 pm
hey guys,
first off, i just joined the forum. Im happy to be here. Seems like a incredible resource.
So, I just started film school. All our edit suites use final cut studio 2. And they have no intentions to upgrade, (at least any time soon). Now, on my macbook, i also have final cut studio 2. But i plan on buying fcs3. I will be getting the academic version as im not eligible for the upgrade.
So 2 questions.
I know i am able to share projects between FCS2 and FCS3 if i save as XML. Is it as easy as just saving it as a XML in FCS3 and opening it FCS2? just like that?
Also, would there be any way to run both fcs2 and 3 on my mac? and just use 2 for school and 3 for personal stuff. It seems like a waste of space, but i dont even have the contents for all the programs for studio 2. So studio 2 is only like 3 gigs. So i'd be willing to leave it installed.
Thanks in advance.
Shane Ross
Re: Final Cut 6 and 7
on Sep 21, 2009 at 10:39:27 pm
[James Tayler] "I know i am able to share projects between FCS2 and FCS3 if i save as XML. Is it as easy as just saving it as a XML in FCS3 and opening it FCS2? just like that?
Yup. Export XML version 4 and it works like a charm.
[James Tayler] "Also, would there be any way to run both fcs2 and 3 on my mac? "
Not on the same OS. You would have to have TWO partitions, or a separate hard drive with separate OS and FCS install. Cannot run both on the same system...too many shared components and possible conflicts.
Shane
