Outputting in 4:3
Jan Becker
Outputting in 4:3
on Sep 18, 2009 at 8:07:30 pm
Hi there,
I finished editing in native DVCPro HD and now I would like to output it NTSC DV 4:3.
If I do it in compressor it's squeezed.
So what I would like to do is crop the sides, so it's 4:3 unsqueezed. How do I do it?
Thank you,
Jan
John Fishback
Re: Outputting in 4:3
on Sep 19, 2009 at 9:15:37 pm
I'm not at the office so I can't give you the exact answer. Look at Compressor's Inspector. In the Video tab there should be a choice for letterbox in the aspect ratio choices. Or it might be applied as a filter. Check out the manual. Search for letterbox and I'm sure the exact info will be there.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
