FCP7 Won't render any audio.
James Hart
on May 11, 2016 at 11:21:58 am
My FCP7 has decided (I'm probably at fault) that it just won't render any audio. It will happily play aiff audio, but the majority of my clips are MP3 or WAV.
I've tried all the various render options for both the sequence or an individual clip ie Sequence > Render Selection > Audio
I realise I can convert audio to aiff but I don't want to have to workaround all future audio if there is a fix I'm just not seeing. One more nudge toward FCP X? :(
Thank you in advance,
James
Nick Meyers
Re: FCP7 Won't render any audio.
on May 11, 2016 at 11:40:21 am
there the render options under Sequence > Render Only.
your WAVs should be fine, but mp3s are a risk in FCP.
i always convert to AIFF, it doesn't take long using QuickTime player7
i've also got a Compressor droplet always close to hand, (in my finder window's Toolbar)
that makes it very painless.
nick
James Hart
on May 11, 2016 at 11:43:50 am
Thanks Nick, will give it a go.
Why are mp3's a risk? I thought FCP was designed to stomach all manner of files, let alone such a common audio type.
James
Nick Meyers
on May 11, 2016 at 11:50:10 am
the older FCP is a bit more particular about what files it plays.
yes it SEEMS to work: you can put these files in your timeline, and edit,
but when it comes time to export, there can be unpredictable issues, like sync being way off.
nick
