Final Cut Pro 6.0.6 Files are not what I want outputed
Michael Scheutzow
on May 11, 2016 at 4:23:48 am
What is happening is this. I created a project and in the time line when viewing the project it is correct. When I go to make a .mov file there are clips that are not suppose to be there and there are clips that have the input and output wrong. For example: I watch the file on the timeline and it is correct in the viewer. When I goto make a .mov file the audio is off and so are the clips. Please help, project is due Monday. I have tried to copy and paste the project into a new project, I have restarted the computer, I have moved all the files to an external harddrive and tried another computer, no success. Please help.
David Roth Weiss
Re: Final Cut Pro 6.0.6 Files are not what I want outputed
on May 11, 2016 at 5:40:55 am
FCP does this when you try to edit h.264 files. If I'm correct, you'll have to transcode to ProRes and recut over your existing cut.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Nick Meyers
on May 11, 2016 at 11:41:43 am
a quick fix could be to change your sequence's settings to Prores, and render it,
then export,
that might work, or it might not.
h264 is rather unpredictable in FCP7
nick
