Delivering in Apple ProRes 422 and at 1080i60, but shot in 24fps
Lena Jackson
on May 7, 2016 at 2:06:38 pm
Hi everyone,
I'm producing a short video for my local PBS station and they want the final product delivered in Apple ProRes 422 and at 1080i60.
Unfortunately, I've already shot 90% of it and was using 24fps.
I'm editing in FCP7 and am wondering whether people have advice on whether to convert all my clips to 30fps now (before I get too far along in editing) or whether I'll be okay exporting the video at 1080i60 once I've finished editing.
Lena
Shane Ross
Re: Delivering in Apple ProRes 422 and at 1080i60, but shot in 24fps
on May 8, 2016 at 2:09:51 am
Keep editing in 23.98. Export a 23.98 ProRes 422 master. Then convert that to 1080i interlaced with Compressor. Use these settings specifically...
1. Drop clips you want to convert into Compressor
2. In Compressor, select your video then right click and choose NEW TARGET WITH SETTING > APPLE > FORMATS > QUICKTIME > APPLE PRORES 422 (HQ). Or pick whatever codec you like to work with.
3. Click on that newly created compression setting to open it in the Inspector window. Click the Encoder tab. Click the Video: (Settingsā€¦) button. Make the frame rate 29.97. Check the interlaced box. Set it's drop down menu to Bottom field first. Click OK.
4. Click the Frame Controls tab. Set Frame Controls to On. Set Output Fields to Bottom first. Leave Deinterlace on Fast. Leave Adaptive Details checked. Leave Rate Conversion set to Fast. Leave the Set Duration to: on 100% and make sure it's radio button is selected and NOT the "so source frames play at 29.97 fps" button.
5. Make changes to the Filters or Geometry sections as needed. Those settings listed above are the ones critical to getting the proper 3:2 pulldown added.
6. Submit the compression, then bring the resulting video back into Final Cut Pro. Place it in a 29.97 timeline and make sure you watch it on an NTSC monitor to verify that it looks good. If you step through it frame-by-frame you should see the familiar pattern of 2 split/interlaced frames followed by 3 whole frames. This is a very important step. I tried many solutions that looked OK playing back on the computer monitor, but looked terrible on the NTSC monitor.
Shane
Little Frog Post
Lena Jackson
on May 8, 2016 at 2:20:30 am
Thank you Shane!
Michael Gissing
on May 11, 2016 at 6:35:16 am
Is 1080 60i lower field? I thought interlaced HD was upper for all frame rates?
