640x480 vs 720x480 complication
Pam Thompson
on May 1, 2016 at 4:33:02 am
I am preparing to edit old SD DV Mini tape previously captured. I was under the impression the footage was all 720x480 as seen in FCP7 board (in pic below) however when loading the clips into CatDv I discovered some were digitalized as 640x480 4:3, and others at 720x480 3:2. Can this be corrected by converting to pro-res or am I doomed to re-digitizing?
Thank you !
