Multiclip Editing. FCP 7
Lane Cameron
on Mar 10, 2016 at 2:25:47 am
I have synced 2 camera files and one external audio file in PluralEyes 3.5. I imported the XML file into Final Cut 7. I play it in the time line switching between video and it's all synced up. However I can't for the life of me enable the multi-clip function in the Modify menu of FCP7. Any help would be appreciated.
Thanks Lane.
Here's a screen shot of my timeline.
screenshot2016-03-1011.33.01.png [x]
Shane Ross
Re: Multiclip Editing. FCP 7
on Mar 10, 2016 at 6:18:14 pm
If you use Pluraleyes, you can't multiclip. Pluraleyes makes a stacked sequence that you bring into FCP. You can't make multiclips out of sequences. YOu need to edit with the sequence. Multiclips are made when you select clips in a bin, mark IN points at sync points or use common timecde, and then multiclip them. But if you use Pluraleyes, you can't do this. Gotta work from that sequence.
Shane
Little Frog Post
Lane Cameron
on Mar 11, 2016 at 1:35:42 pm
Thanks Shane. Appreciate your help.
