How to lose unwanted audio tracks
Vic David
on Feb 18, 2016 at 3:16:31 am
Hello,
I am a shooter. Occasionally, under protest, I have to cut my material on the field. Sometimes, I have to do it really fast. And that's where I am dealing with the issue like that:
My camera, SONY FS7 records 8 channels of audio. I only need first 2. Now, every clip imported into FCP7 has 8 channels. So, i have to place them onto the timeline, unsync them, delete unwanted tracks, sync them again. It slows down the process tremendously. I know there's a way to lose all unwanted audio tracks in the editor window. Or possibly even while importing. Please, help.
Vic
Studio 7NY
G5 Dual 2 Ghz, Leopard, FCP Studio 2, Blackmagic HD, ATTO UL4D, MOTU V3HD
Mark Suszko
Re: How to lose unwanted audio tracks
on Feb 18, 2016 at 2:42:13 pm
User prefs, timeline options, look to the right hand side and pick the default number of audio tracks you want.
Shane Ross
on Feb 18, 2016 at 5:08:43 pm
Do you use Log and Transfer to bring in the footage? In the audio tab of that you can tell FCP to only import the tracks you want.
Shane
Little Frog Post
Nick Meyers
on Feb 19, 2016 at 1:59:02 am
what Shane says
OR,
if you really want to get rid of those empty tracks for good from the master file
use an app called QTChange
http://www.videotoolshed.com/product/42/qtchange
"i have to place them onto the timeline, unsync them, delete unwanted tracks, sync them again. It slows down the process tremendously"
there is a quicker way:
lock the picture,
lock the 1st 2 audio tracks,
select all, delete.
then…
copy all in the timeline
delete the original clips from the browser,
copy the 2tk clips into a new bin.
now you have 2tk master clips, and match framing should bring up the 2tk version.
nick
Vic David
on Feb 19, 2016 at 7:46:13 am
Thank you, all. I am importing XDCAM files. So, someone suggested in preferences to check "Import only 1/2. that's exactly what i needed. Thank you for your help!
Studio 7NY
