FCPX: Hollow circle on the bottom left corner of clip thumbnail, creating problems exporting
Jasmine Rao
on Jan 29, 2016 at 9:45:45 pm
Hi, I am working in FCPX 10.2.2 and I just imported footage and some of the clips have a little hollow white circle at the bottom left corner of the thumbnail of the clip.
The footage is c100 footage that I directly imported into FCPX. Some c100 footage does not have the circle and some does. I think part of the problem may be that there are clips with the same name in the project? This circle does not go away. I wouldn't have thought much about it because I can still see the clip and work within FCPX but I did a test and I am not able to export. What does this circle mean? How can I get rid of it/ successfully export? Any help would be great!
Jasmine Rao
Re: FCPX: Hollow circle on the bottom left corner of clip thumbnail, creating problems exporting
on Jan 29, 2016 at 9:54:10 pm
Should I maybe have not directly imported the c100 footage into FCPX without converting it? This is my first time using c100 footage in FCPX
Jasmine Rao
on Jan 29, 2016 at 10:19:37 pm
ok, the circle has now become a camera at the bottom left corner
