lumix gx8 24P UHD importing as 23.98
robert shanks
on Jan 12, 2016 at 11:15:38 pm
can anyone pls tell why lumix gx8 24P UHD is immporting as 23.98 in fcpx 10.2.2 - and how to fix...pls
ROBERT SHANKS
Shane Ross
Re: lumix gx8 24P UHD importing as 23.98
on Jan 12, 2016 at 11:53:31 pm
Because video at 24fps runs at 23.98. Only film, and high end cameras run at 24fps straight up. 24p video is 23.98...well, pardon, 23.976.
Shane
Little Frog Post
robert shanks
on Jan 13, 2016 at 1:14:44 am
Thank you....any way to overcome sync issues from external recorded audio...thank you
ROBERT SHANKS
Shane Ross
on Jan 13, 2016 at 1:51:07 am
What was used to record audio? Did it record it at 44.1kHz, or 48kHz?
Shane
Little Frog Post
robert shanks
on Jan 13, 2016 at 2:06:13 am
tascam 70d
ROBERT SHANKS
robert shanks
on Jan 13, 2016 at 2:08:46 am
44.1
ROBERT SHANKS
Shane Ross
on Jan 13, 2016 at 2:10:01 am
It should have been recorded at 48kHz. That's what's needed for video sync. You might be able to convert it after the fact and have it sync. Compressor can do this....there are presets.
Shane
Little Frog Post
robert shanks
on Jan 13, 2016 at 2:14:19 am
convert the 23.976 video to 24p?
ROBERT SHANKS
Shane Ross
on Jan 13, 2016 at 2:21:55 am
No...that won't do anything. The issue is that the audio is 44.1. It needs to be 48k.
Shane
Little Frog Post
robert shanks
on Jan 13, 2016 at 2:23:53 am
ok...many thanks for ur help and patients...
bob
ROBERT SHANKS
