Horizontal lines visible in Video When Viewing on 30" Cinema Display Monitor
Daniel Monskey
on Dec 30, 2015 at 2:48:36 pm
I have never seen this condition before. I do not know if it is a graphics card issue or an OS issue or something else.
Recently I replaced my 2008 Mac Pro (it died) with a different 2008 Mac Pro computer. It has a new Solid State Drive for a start up disk, EL Capitan for the OS and a replacement graphics card I was told would be better than my original one.
Graphics: ATI Radeon HD 5770 1024 MB
When I reloaded all my original software I could no longer use some of the original versions (Adobe AE, Photoshop, Illustrator) so I upgraded and am using the cloud versions. After Effects mentioned I need to use a special version of graphics card, but the program will make due somehow with adjustments or something.
I am using Final Cut Pro 7.0, as I had been with my original computer.
Just on my most recent project (the first since my computer replacement and upgrades) I now frequently see horizontal lines across my screen. I had thought my system just couldn't keep up with the HD video when playing. I have added some special effects (flashes I created myself years ago) to the video, which I have done to many of my previous videos. Every one of the flash effects have lines going across them when I review the video---although they are not there if I advance frame by frame. There are only about 2-3 of these horizontal lines in the whole screen, not like an interlace issue with dozens of them up the screen. These lines show up every now and then in regular clips as well during video play.
I wonder if this is a graphics card issue and I have to replace that now, if it is my OS not liking some old effects graphics or if there is something else causing this.
Dan
Daniel Monskey
Mark Suszko
Re: Horizontal lines visible in Video When Viewing on 30" Cinema Display Monitor
on Dec 30, 2015 at 3:53:47 pm
Curious: what do the frames with the flashes and the frames with lines thru them look like on the wave form monitor? What I'm getting at is, maybe this is an artifact from video levels being over 100 IRE?
Daniel Monskey
on Dec 30, 2015 at 11:40:01 pm
Here is the waveform and the accompanying image for the clip adjacent to it. It is very hot, but I have used these flash effects for years and never had this problem. (I hope the image shows up and I am following directions properly). Plus, other clips with softened white are also having the problem now and then that do not have the flash effect on them.
Daniel Monskey
