Mixed SD and HD footage - what to do?
Niklas Wikman
on Dec 28, 2015 at 5:52:18 pm
9 mins long, 7 mins is DV50 PAL, 1024x576.
The rest is 720P50
If I place the HD footage on the SD timeline, it scales down just fine. But I do get moving artifacs, or rather a sense of "film". I guess thus is because of the default frame rate.
Is there anythin I can do to make the HD footage "mix" better with the SD footage? You also see the effect in dissolves between the HD and SD footage.
Shane Ross
Re: Mixed SD and HD footage - what to do?
on Dec 28, 2015 at 7:11:32 pm
[Niklas Wikman] "DV50 PAL, 1024x576."
How is your SD footage this dimension? That isn't the normal dimensions for PAL SD. 720x576 is.
Shane
Little Frog Post
Niklas Wikman
on Dec 28, 2015 at 7:35:44 pm
Of course it is 720x576. But since it is widescreen, the ref movie plays at 1024x576.
I guess the best thing would be to use either Episode 6 or perhaps Compressor and transcode the 720P50 footage to SD....?
