Error while exporting 30 min. video from FCP7 into .MXF file using Sony XDcam plug-in
kim manis
on Dec 23, 2015 at 6:28:37 am
Dear all,
I've used Final cut pro 7 to edit my project in Apple pro res 422 and need to submit the work in .MXF file.
Well, I suceesfully exported my 1 min. teaser via sony xdcam plug-in with the video and audio codec: XDCAM 422 HD 1920 x 1080i50 cbr/8 channels but there is an error while exporting my 30 mins project and even it seems to be completely export but it has exported only half of my project.
Does anyone now how to fix this problem or do you have any other better way to export my projection .MXF?
Thank you very much..
Kim
John Rofrano
Re: Error while exporting 30 min. video from FCP7 into .MXF file using Sony XDcam plug-in
on Dec 23, 2015 at 4:11:00 pm
[kim manis] "Does anyone now how to fix this problem or do you have any other better way to export my projection .MXF?"
Why not export to ProRes 422 and then use Apple Compressor to convert that to MXF? That should eliminate whatever problem FCP 7 is having with exporting to MXF.
~jr
http://www.johnrofrano.com
http://www.vasst.com
kim manis
on Dec 23, 2015 at 8:52:26 pm
Oh...yes!...I'll try on that..thank you very much! ^^
