FCP7 Sequence preset question- $20 paypal tip to best answer!
Dan McGuire
on Dec 10, 2015 at 5:29:04 pm
This question should be answered by someone who has taken a multi-system project from Final Cut 7 to Final Cut X or premiere.
Here's my problem. I have an old project that I am reconstituting. Most of the footage we shot with a DV camera it was then dubbed to Beta SP, and then digitized using Prores.
I also have footage which is NTSC DV footage which was digitized via a FireWire. I also have some DV PAL footage also digitized via FireWire. And most recently I've added a bunch of footage that we shot on HD, now in Prores.
Ultimately, we need to output the project to HD.
So my question is this. Do I create new sequences in FCP7 that are HD and RES? Or do I create sequences which are DV?
Or do I continue to use the old sequence settings that I started the project with. (Which are 720×480 aspect ratio NTSC DV 3:2 Pixel aspect ratio and NTSC – CCIR 601 – DV 720 x 480.)
Or do I create a new sequence that has HD ProRES settings? When I do this now the files all need to be rendered before I can work in the program. Even the Prores SD files. I'm not sure why this is, but that is the case. The SD footage is small in the viewing window, but when I drop HD footage in an SD sequence, it scales to fill (though there are black bands top and bottom due to change in aspect ration.
Thanks for any help that you can give me.
Shane Ross
Re: FCP7 Sequence preset question- $20 paypal tip to best answer!
on Dec 10, 2015 at 5:51:42 pm
[Dan McGuire] "so my question is this. Do I create new sequences in FCP7 that are HD and RES? Or do I create sequences which are DV?"
HD. And then you'll need to convert all of your footage to HD as well. FCP does not scale SD footage well. Premiere Pro does...very well. FCP 7...not so much. If you want, you can edit all the SD footage in that HD project, and then media manage only the SD footage, and only what's in the cut, and then upconvert only that small batch of footage. I do that all the time for docs. Just finished doing it again, as a matter of fact.
[Dan McGuire] "Or do I continue to use the old sequence settings that I started the project with. (Which are 720×480 aspect ratio NTSC DV 3:2 Pixel aspect ratio and NTSC – CCIR 601 – DV 720 x 480.) "
NO! Putting your HD footage into this will make it look like poo. And then when you try to make it HD later...you'll take a lot of time fixing things. The rule always is work in the sequence that matches the footage, OR...matches what you want to output. Unless ALL of the footage is SD. Then I'd cut SD and output and upconvert that output. But you are mixing HD, so cut HD.
[Dan McGuire] "Or do I create a new sequence that has HD ProRES settings?"
Well...yes, that would be the sequence you'd use...as the answer to the first question.
[Dan McGuire] "When I do this now the files all need to be rendered before I can work in the program. "
No, they don't. THey will be GREEN, meaning they will play back without rendering. You CAN render, but you don't need to. If they are anything other than green, then you need to adjust your RT settings to UNLIMITED.
[Dan McGuire] "The SD footage is small in the viewing window, "
Yup...you'll need to scale it about 300%. And only temporarily. For best results you need to media manage this footage, and either recapture the tapes via a Kona card for hardware upconvert (best)...or use Compressor to upscale the footage (second best)...and then relink to those new masters.
[Dan McGuire] "(though there are black bands top and bottom due to change in aspect ration."
There should be black "pillar boxes" on the sides...as the 4:3 footage won't fill the 16:9 frame. So either leave them pillar, or zoom in even more to fill the screen.
Shane
Little Frog Post
Dan McGuire
on Dec 11, 2015 at 8:10:06 pm
Shane, Thanks for this.
I'll kick you some $ if you get me an email address. I'm dandmcguire at gmail.
I will eventually need to online this project in either Premiere or FCPX, and also need to think about making that transition. I assume I can continue to work with FCP7 until I need to output my xml and import it in to another program - FCPx seems to allow you to change the sequence settings after the fact.
Am I right in thinking that I can drop SD NTSC and SD PAL and HD 1080 24fps footage all in the same sequence of FCPX or Premiere? My footage is 85% SD NTSC, 5% SDPAL and 10% HD. In addition to the resolution issue, there is a frame rate issue. I hope to eventually output at 1080p 24 fps.
Thanks again.DAN
Shane Ross
on Dec 11, 2015 at 9:31:34 pm
Keep the money. Pay it forward. Do something nice for someone else. That's how this works.
Shane
Little Frog Post
John Rofrano
on Dec 12, 2015 at 12:14:56 am
[Dan McGuire] "Am I right in thinking that I can drop SD NTSC and SD PAL and HD 1080 24fps footage all in the same sequence of FCPX or Premiere? My footage is 85% SD NTSC, 5% SDPAL and 10% HD."
Yes, you can drop them all into an HD FCP X project and the SD video will be scaled automatically (you can control this with the Spacial Conform options) but you will have to deal with any mismatch between 4:3 and 16:9 aspect ratio issues manually.
[Dan McGuire] "In addition to the resolution issue, there is a frame rate issue. I hope to eventually output at 1080p 24 fps."
Yes, you will have frame rate issues. ;-)
FCP X will handle the NTSC 29.97 fps footage in a 23.976 fps project just fine but the PAL 25.0 fps footage will play back slower. You will need to Retime (⌘R) it by 105% to make the 25.0 fps footage match the 23.976 fps project. You will also need to turn off Preserve Pitch so that the audio is retimed and transposed as well. If you don't do both the audio will be lower in pitch than the original.
Bottom line: nothing that isn't easily fixable in FCP X.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Sean Thomas
on Dec 24, 2015 at 6:41:13 pm
Our workflow has always been to first, convert all SD digital files to HD using compressor. This makes editing much easier and faster, AND the quality seems to be better using compressor conversion than any other method I've tried. The only negative is it takes a long time to render the conversions. But this has to be done somewhere, and hopefully not in your edit timeline.
Shane Ross
on Dec 24, 2015 at 7:16:06 pm
Compressor is OK. Premiere Pro and After Effects are better. And hardware conversion....Terranex, AJA Kona cards, Snell Wilcox...are even better. That being said, I do use Compressor a lot.
Shane
Little Frog Post
Dan McGuire
on Dec 24, 2015 at 10:48:10 pm
Thanks to all for these tips. Very much appreciated.
Sean Thomas
on Dec 24, 2015 at 10:48:21 pm
Thanks for the good info Shane.
In my case, I have a BMD DeckLink Studio 2 and did a 3 way test for some BetaCam SP to HD conversions. BMD real time hardware conversion, AE scale to HD, and Compressor. I analyzed all of the still frames and Compressor looked the best.
BMD was almost as good, but I could only go from 29.97 to 59.94 in order to use the hardware. My client wanted 30p so I couldn't use that method.
Dan McGuire
on Dec 24, 2015 at 10:50:53 pm
Are there any settings you would suggest in Compressor? I need to look at all the options, but I assume there are things like frame blending and interpolation. Remember I need to end up at 24p HD. Thanks again.
Sean Thomas
on Dec 26, 2015 at 8:49:10 pm
I just take one of their presets and "mod" it as needed. I may end up with 4-6 variations that I then test and look at the quality difference vs. compression time and file size to see what works best overall.
You may find that you can't use 2 of the spatial parameters as it will yeild an error and not render. Google to find the full story.
I found this to be a non-issue and always get great, but slow, results from compressor.
Shane Ross
on Dec 24, 2015 at 10:52:32 pm
Earlier Blackmagic capture hardware didn't do HARDWARE scaling...they did it in software. Only AJA and Matrox did hardware. Now, more recent BMD hardware does do hardware scaling. That's why Compressor looked good to you
Shane
Little Frog Post
Dan McGuire
on Dec 27, 2015 at 10:38:15 pm
Did Aja or Matrox ever make a card for a mac Power PC tower that would convert to HD and scale? I have an old mac tower and it would be better to convert from a deck via an old mac than have to buy a new card and a new mac tower running OSX.
Still got $20 burning a hole in my paypal account!
DAN
Dan McGuire
on Dec 27, 2015 at 10:43:33 pm
Did you keep the 4/3 aspect ratio of your SD footage or crop it to 16:9?
I plan to keep the aspect ratio 4:3, and wonder what settings would be used to up-res it? My current digital SD files are Prores 720X486, 29.97 fps, 24 bit audio Little endian.
Compressor doesn't seem to offer a prores HD 4:3 preset. What would be the settings? Would it stay in Prores?
Thanks.
Shane Ross
on Dec 28, 2015 at 4:22:18 am
"Did Aja or Matrox ever make a card for a mac Power PC tower that would convert to HD and scale?"
AJA...yes. The AJA Kona 2. Only way to get it would be used. Matrox didn't make hardware for the PowerPC. They did a DVI unit (Matrox MXO) and then PCie and Express34 slot MXO2 options.
[Dan McGuire] "I plan to keep the aspect ratio 4:3, and wonder what settings would be used to up-res it? "
There are options to keep 4:3. I do that myself. It's called Pillarbox.
[Dan McGuire] "
Compressor doesn't seem to offer a prores HD 4:3 preset. What would be the settings?"
Because there really isn't a 4:3 HD format...you need to make on. 1440x1080 Square Pixel. Gotta make a preset.
Shane
Little Frog Post
Sean Thomas
on Dec 30, 2015 at 9:25:31 pm
Our goal was to take Beta SP SD 720x486 4:3 to HD 1920x1080 30p. In order to do this I used a ProRes 1920x1080 HD setting in Compressor and changed a few parameters to get the tech results I wanted.
Like Shane said, HD 4:3 is not an option. You will be laying in a 4:3 video into a 16:9 space, thus creating letter boxes on the sides called pillar boxes.
