Exporting 5.1 Stems form FCP
Nick Meyers
on Nov 4, 2015 at 12:04:49 am
i've been making some cuts to a film using the existing 5.1 stems, Dialogue, Effects, Music
i'm going to re-export as a single 5.1 group.
this will be used in a DCP, and for a screening from Quicktime
my thinking is to set up 6 mono outputs, all with 0db downmix
then assign the appropriate tracks to the appropriate outputs.
i see FCP has a default 5.1 audio output setting, which is NOT set up like this.
my guess is this is just (as it says) just for monitoring, and my 6 mono output is correct for what i need,
but i just wanted to check with the expoerts.
maybe 6 mono for CDP, and FCP's 5.1 for the Quicktime??
nick
