 | FCP 7 problem with exporting sequence with discrete channels
on Nov 2, 2015 at 3:36:17 pm |
Hi, I am doing a project with a moving background and tone audio for a slide that will loop on our server. The project needs to have these settings (which it does) But when I go to export it I have no audio. If I export it with stereo audio I do have audio but the settings need to have discrete channels. What am I doing wrong?
"Appropriately encoded clips for playback in Ki Pro must have the following properties:
A supported codec: Apple ProRes 422 (LT)
A supported frame size: 1920x1080 for 1080 HD
A supported frame rate: 29.97 fps for 1080i material
Proper interlace setting for interlaced material:HD interlaced material will be top field first
Proper sound settings: Format > Linear PCM, Channels > 2 Discrete Channels,
Rate 48.000 kHz, Sample size 24 bits, and Little Endian.
 | Re: FCP 7 problem with exporting sequence with discrete channels on Nov 2, 2015 at 4:24:23 pm |
How are you creating the file for delivery?
Dave LaRonde
Promotion Producer
 | Re: FCP 7 problem with exporting sequence with discrete channels on Nov 2, 2015 at 4:49:14 pm |
I am using FCP7 to create an mov
 | Re: FCP 7 problem with exporting sequence with discrete channels on Nov 2, 2015 at 5:45:32 pm |
If your edit timeline is set to those delivery specs, just export. Upi wouldn't have to export using quicktime conversion. Discrete audio means that the audio is NOT embedded in the video -- there's an audio track. And it can be stereo with 2 channels for right and lefts, which is what I assume you want.
Dave LaRonde
Promotion Producer
