Convert .MOV file (15-20 GB) to .MXF file ???
kim manis
on Oct 30, 2015 at 9:13:20 am
Hello Guys, I'm pretty new to this editing career and I need some help.. T T
I've got H.264 footages from DSLR camera and I recompressed them to Apple pro res 422 LT for editing with final cut pro 7. with this sequence setting:
Then I need this following output:
Video Codec: XDCAM HD 422 50mbps 1920x1080i @25fps
Audio Codec: 8 channels 24bits PCM
Wrapper: .MXF
What is the best way the get this outcome with the accurate codec and vdo quality?
Thank you very much..
Shane Ross
Re: Convert .MOV file (15-20 GB) to .MXF file ???
on Oct 30, 2015 at 5:30:36 pm
First off, you need to have your audio mixed and laid out on the timeline properly. Meaning what's required as the audio deliverable be mixed and exported as 8 audio STEMS. Put those 8 STEMS on the timeline, go into the Sequence Settings, AUDIO tab. Make the output 8 channels...all DUAL MONO.
Then go to the FILE menu, EXPORT...SONY XDCAM.
Shane
Little Frog Post
kim manis
on Nov 2, 2015 at 9:51:21 am
Thank you very much Shane Ross. I will try with your advice and i'll let you know the result.
Cheers!
Kim
