White line along bottom when uploading to web an FCP7 export
Simon Grant
on Oct 28, 2015 at 6:04:09 pm
I'm using a custom aspect ratio when I export, 1920x817 or 2.35:1
I click preserve using crop, and export. The QuickTime file looks fine, no line. It's only when I upload to Google Drive or DropBox that a white line appears running across the bottom.
Dave LaRonde
Re: White line along bottom when uploading to web an FCP7 export
on Oct 28, 2015 at 9:54:22 pm
That's because FCP stinks at working with non-standard horizontal & vertical resolutions. You're seeing the result of that.
You can live with it, or just letterbox what you have in a 1920x1080 edit timeline.
Dave LaRonde
Promotion Producer
Shane Ross
on Oct 28, 2015 at 10:06:15 pm
Actually...the exported Quicktime is fine. So FCP wasn't at fault, nor is Quicktime. The issue arises when it's uploaded...so the issue lies with the websites and how they compress the uploaded file.
Shane
Little Frog Post
Christopher McDonell
on Oct 29, 2015 at 5:53:55 am
Yeah video looks terrible on Dropbox and you have no control over the compression. You're better to either make your own mp4's (I use Compressor) and upload to an FTP and share the link, or upload to Vimeo and share that.
