exporting: XML Translation was aborted due to a critical error
peter brelan
on Oct 24, 2015 at 10:20:44 am
I can't export a XML to Davinci Resolve
I get this message around 18% "XML Translation was aborted due to a critical error"
If I unchecked "Save project last metadata" the export of the XML works, but if I need to keep metadata, how can I fix this problem???
Thank you
Pierre
peter brelan
Re: exporting: XML Translation was aborted due to a critical error
on Oct 24, 2015 at 1:43:17 pm
i'm think the problem comes from the multi clip editing, but even if I collapse the multi clip, I got the error. Do you know how to keep only the selected take in the multi clip?
peter brelan
on Oct 25, 2015 at 2:26:38 pm
no finally, the problem doesn't from the multiclip, I'm still looking for a solution
