Frame rate conversion yields non-sync audio
Gerret Warner
on Oct 8, 2015 at 4:48:43 pm
I feel as if I've solved this before, but I can't remember how.
I'm trying to add video diaries from a smartphone as 30fps MP4s to a ProRes 422 24fps timeline in FCP 7, but when I convert the files in Compressor the resulting videos have lost sync.
Thanks for any help.
GW
Shane Ross
Re: Frame rate conversion yields non-sync audio
on Oct 8, 2015 at 5:00:21 pm
OK...this being from a phone...30fps straight up? or 29.97? 30fps straight up converted might be an issue. Because 30fps is a non-broadcast frame rate. And your sequence is 23.98, right? not 24fps straight?
Try MPEG STREAMCLIP possibly...although it's not good at frame rate conversions. What I would do in your shoes is convert the footage to 29.97 ProRes...and import that. Avid does a good job of mixing frame rates properly.
Shane
Little Frog Post
