Adding "flickering lights" into videos
Sookyung Jin
on Oct 4, 2015 at 9:11:21 am
at around the 0:12 and 0:25 mark you can see they add in some sort of flickering light.
I've heard it's part of Final Cut Pro but I can't seem to locate it...any ideas?
Roger Poole
Re: Adding "flickering lights" into videos
on Oct 4, 2015 at 11:49:46 am
This should be quite easy to do. Go to video generators/matte/color. Make it any color you like and then place it above the video track. Turn down the opacity then chop it up into small segments and remove alternate segments so that it flashes on and off. You can also stack different colors one above the other.
Sookyung Jin
on Oct 4, 2015 at 3:57:44 pm
Thank you for your response. Under Generators, I only have Backgrounds, Elements, Solids and Textures. No "matte/color." Am I looking in the right section?
Sookyung Jin
on Oct 4, 2015 at 4:05:31 pm
Oh wait, I found a transition that looks similar to the video. However, how do I change the color and opaqueness? Right hand clicking doesn't seem to be working.
Nick Meyers
on Oct 4, 2015 at 8:29:25 pm
[Sookyung Jin] "Under Generators, I only have Backgrounds, Elements, Solids and Textures"
are you using FCPX?
this forum is for FCP7 and under
the FCP X Techniques forum is the one you need
nick
Roger Poole
on Oct 4, 2015 at 10:05:28 pm
Ahh, Nick beat me to it. Yes this forum is for FCP7 and earlier. I'm not the sharpest tool in the box when it comes to FCPX, however, here's a demo of how to change the color and opacity of a generator in X.
Joe Barta IV
on Oct 5, 2015 at 3:06:49 pm
They are called Light Leaks and they can be found in a number of plug-ins or transitions from 3rd party developers like Digital Juice or Film Impact.
Joe
Living the SuiteLife!
Stuff for editors http://www.cafepress.com/suitelife
http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
Roger Poole
on Oct 5, 2015 at 3:54:37 pm
Well he did say "within FCP", or words to that effect. But thanks for posting this info Joe. I just downloaded some Light Leaks to try, they look cool. :o)
Mark Suszko
on Oct 6, 2015 at 3:03:31 pm
Rampant offers a ton of these light leaks and other film grunge: a number of them are free. You just add them to the video track above where you want the effect, set the blend mode and done.
