Problems with XDCAM Transfer en FCP 7
Michel Supertramp
on Sep 29, 2015 at 2:23:09 am
Hello!
I'm trying to export an MFX XDCAM HD422 file from my sequence using XDCAM Transfer but I keep getting the following error:
Please check that the volume to which you are exporting is not locked or full. Error opening movie (while checking valid media time scale).
I have more than 200 GB on the drive so that shouldn't be the problem
My sequence is set up as XDCAM HD422 1080p30 (I used progressive as I need to use huge fast motions in many clips)
Someone got this error in the past? How can I fix it?
Thanks!!
