General Error Message when using DSLR Footage in Timeline
Dean Longfield
on Aug 26, 2015 at 3:18:02 am
I am using FCP 7.03. When I try to bring in footage from the browser into the timeline, it allows me to do it the first time. Then on the 2nd or third clip I bring in it says General Error and the Canvas and Timeline disappear. The footage is from a DSLR.
When I first tried to make the new project and brought in the DSLR footage, it said I was out of memory. yet when I checked, I still had 12 Gigs of free DDR, which made no sense. So I went ahead and deleted a lot of footage that was already finished and deleted other finished projects,
and am still getting the Error Message, (but no longer get a message telling me I'm out of memory).
As usual, the client needs the project yesterday. Has anyone run into this before?
Thanks.
Nick Meyers
Re: General Error Message when using DSLR Footage in Timeline
on Aug 26, 2015 at 4:22:03 am
you need to transcode the DSLR footage into something FCP7 is happy with, like ProRes.
it can choke on h264, or other non-standard material.
nick
Dean Longfield
on Aug 26, 2015 at 3:09:35 pm
Thanks for your reply. Thing is it's never done this before, and I've been editing on this set up since 2008 or so.
Dave LaRonde
on Aug 26, 2015 at 3:16:30 pm
You've been extremely lucky that you've been able to cut in H.264 since 2008. Lucky beyond all imagination, in fact.
I would say your luck has run out, and it's high time to adopt Standard Operating Procedures for FCP... and that's to transcode H.264 footage to Prores.
Dave LaRonde
Promotion Producer
Shane Ross
on Aug 26, 2015 at 3:58:37 pm
Yeah...DSLR's shoot H.264, and FCP doesn't work with H.264 reliably. You always need to convert media to a format FCP works with....ProRes being the best codec.
I'm sure you've edited a lot of video with that setup, but many formats don't edit natively in FCP...and H.264 is one of them. Gotta convert, then import...then edit.
Shane
Little Frog Post
Dean Longfield
on Aug 26, 2015 at 6:32:10 pm
Thanks very much for the feedback. When I said, "this setup since 2008"
I was thinking that I've been editing on this particular Mac with FCP since 2008. With DSLR footage only being incorporated over the past 3 or 4 years, and only in the past couple years have I been making projects with just the H264 footage and not mixing in other formats like AVCHD, (which automatically converts to Apple Pro Res if it's the first clip in the timeline).
Right now I'm converting the H264 footage to APR with MPEG Streamclip.
I'm noticing that it isn't naming separate clips as they show in the window, but it seems to be calling all the clips the title of the first clip, (MVI_6135.MOV). Will I be able to see these clips as separate when the conversion process ends or will it be one large (in this case 59 minutes) clip?
I'm wondering if I should just make an APR 422 Timeline and then bring in the H264 clips and convert them in FCP.
Any suggestions?
...and thanks again for the advice. Very much appreciated !!!
Shane Ross
on Aug 26, 2015 at 6:50:19 pm
[Dean Longfield] "I'm noticing that it isn't naming separate clips as they show in the window, but it seems to be calling all the clips the title of the first clip, (MVI_6135.MOV)"
So you are batching with MPEG STREAMCLIP...and it isn't making separate clips? I'll admit, I don't use MPEG STREAMCLIP to batch. When I have a lot of files to convert, I use Compressor. Names retained.
[Dean Longfield] "I'm wondering if I should just make an APR 422 Timeline and then bring in the H264 clips and convert them in FCP."
No...how would you convert INSIDE FCP? Media Manager? Well, that's one way. But Compressor is better. Convert first, then import...and use a new timeline, APR422...to match.
Shane
Little Frog Post
Nick Meyers
on Aug 27, 2015 at 6:47:22 am
you could convert in FCP if the DSLR has an appropriate plugin for FCP's Log & Transfer.
"AVCHD, (which automatically converts to Apple Pro Res if it's the first clip in the timeline)."
are you using FCPX?
there's a separate forum for that, (FCP X Techniques)
this is for FCP7 and under
nick
Dean Longfield
on Sep 2, 2015 at 11:48:33 pm
FCP7.03
