FCP and Compressor Settings for DVD
David Mayer
on Aug 21, 2015 at 12:14:16 pm
My clients still want SD DVDs. I wish they didn't.
These settings work all the way to Simulator in DVD Studio Pro but the DVD player will not even recognize the disk.
The settings must be wrong somewhere, right?
Footage is Quicktime from a Canon C-100.
FCP Export - Apple ProRes 422 NTSC 48 kHz Anamorphic
Compressor "Create DVD" default
to DVD Studio Pro Build and Format
Dave
iMac 2.8 GHz Intel Core i7, 8 GB 1067 MHz DDR3
OS 10.10.4
Final Cut Pro 7.0.3
Compressor 4.2
DVD Studio Pro 4.2.2
Canon C100
Mark Suszko
Re: FCP and Compressor Settings for DVD
on Aug 21, 2015 at 2:12:33 pm
Are you using DVD-R media?
What happens if you skip compressor, and just do it all within FCP7?
Shane Ross
on Aug 21, 2015 at 3:46:28 pm
Will OTHER DVD players recognize it?
Shane
Little Frog Post
David Mayer
on Aug 21, 2015 at 5:51:20 pm
I'm using good media, I have done this before a million times but had to reinstall
everything.
No DVD players will see the disk.
Final Cut to Compressor to DVD Studio Pro is the best way I know how to make a
standard definition DVD.
I think it's a setting somewhere that I've got wrong.
OS 10.10.4
Final Cut Pro 7.0.3
Compressor 4.2
Canon C100
Mark Suszko
on Aug 21, 2015 at 7:28:35 pm
Please, try marking out a one-minute section of the timeline and burn a test DVD using the Share function. Report back on the play-ability.
