Movement doesn't flow when animation is moved from After effects to Final cut
Olly Lawer
on Aug 13, 2015 at 1:36:14 pm
Hi guys,
So, we usually put animations made in After Effects into Final cut to edit (add pauses and sound effects etc). And it is usually fine, but lately once the animation is in Final cut it looks very laggy and like it is bad quality when compared to the .mov file we get out of After Effects. It looks especially bad during moves and zooms.
Does anyone have any idea what could be happening?
Any help will be appreciated.
Thank you!
Olly Lawer
Dave LaRonde
Re: Movement doesn't flow when animation is moved from After effects to Final cut
on Aug 13, 2015 at 4:54:36 pm
It's tough to know what you mean by "bad".
I'll take a stab and say you're working in a fairly low frame rate, which doesn't have the smooth motion of higher frame rates.
If you aren't rendering to ProRes 422 in AE, you may also be experiencing the need to render video in FCP.
Dave LaRonde
Promotion Producer
Nick Meyers
on Aug 13, 2015 at 11:34:07 pm
yes, what is the format of the media from AE?
if your animations are using "Animation" codec, then they will play back the way you describe.
it's data rate is very big.
nick
Olly Lawer
on Aug 18, 2015 at 4:07:14 pm
We solved it by exporting it at a higher frame rate from AE (50 instead of 25). We never had this problem before but this solved it so it's all good! Thank you!
Olly Lawer
