Make Clips Offline:Delete From Disk
William Rudberg
on Aug 12, 2015 at 10:22:14 pm
Hello,
I was editing a project using Final Cut 7 off of a LaCie external 1 tb drive. I had to switch drives recently and some clips weren't connected correctly, so I was going to make them offline and then re-connect them. I went to do this, but accidentally chose to erase them from the disk instead of move them to the trash. Is there anyway to recover these? Or am I completely screwed?
Any suggestions are appreciated.
Nick Meyers
Re: Make Clips Offline:Delete From Disk
on Aug 13, 2015 at 12:32:04 am
you can't recover from that.
you need a copy or backup to retrieve the files from
do you still have the first drive?
nick
William Rudberg
on Aug 13, 2015 at 5:48:21 am
I do, but I dropped it, so I need to get the data recovered. That's my only option huh?
Nick Meyers
on Aug 13, 2015 at 9:37:20 am
well you've deleted the files from the drive.
hard to get back.
i guess you could try.
make sure you don't do ANYTHING more on that drive.
and give it to the data rescue team along with the other one.
nick
William Rudberg
on Aug 13, 2015 at 6:03:32 pm
Alright, thank you. I'll give that a try. I really messed up this time. I didn't realize Final Cut could actually delete the actual files. I figured there would be some kind of safeguard against it. Besides myself. Thanks again.
Billy
