Export with alpha to Animation codec-wrong frame rate?
Tom Matthies
on Jul 31, 2015 at 1:42:39 pm
Looks like this problem has been around for a while but I still haven't been able to find the answer.
I have a short "Snipe" assembled in FCP7. I want to export it as an Animation file with alpha to run on air. When I export from the FCP7 timeline (1920x1080 59.94fps) the resulting file Animation codec file runs at about 6 frames per second. It seems to play normally in Quicktime player, but will run at 6fps when loaded into the on-air playback system. The inro tab in Quicktime player also shows an incorrect frame rate. This problem appears to have been known for a while. Is there a solution to get the resulting Animation file to be the correct frame rate?
Not my monkeys. Not my circus.
David Roth Weiss
Re: Export with alpha to Animation codec-wrong frame rate?
on Jul 31, 2015 at 3:51:04 pm
The animation codec is an old and inefficient codec requires lots of throughput for seamless playback, are you simply dropping frames during playback because your hard drives don't have the necessary throughout?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Dave LaRonde
on Jul 31, 2015 at 4:29:16 pm
What David said.
Animation is by no means a playback codec. It's good because it's lossless & supports alpha channels, but you always have to render Animation-codec footage.
You might give ProRes 4444 a shot. It too supports alpha channels.
Dave LaRonde
Promotion Producer
Shane Ross
on Jul 31, 2015 at 5:01:10 pm
Also...1080 59.94fps? I hope you mean 1080i59.94...29.97fps. 1080 60fps...ANIMATION...is a HUGE data rate to try to play back. And of course on air is only 29.97.
I'm sure you knew that...but the 59.94 is confusing unless you say 1080i59.94
Shane
Little Frog Post
Tom Matthies
on Jul 31, 2015 at 5:03:16 pm
I can't use ProRes 4444. The device that plays the Snipes back on the air requires either an Animation/alpha file or a numbered Targa or PNG sequence. It takes the file or the image folder and renders it out to it's propitiatory file format for playback. The numbered TGA method works but it's understandably a much larger file to deal with and they are having problems positioning it correctly on the screen (OP Error?). The animation file plays in the correct position but it's playing back about 4 times faster than real time. It's supposed to be a 10 second snipe. I exported it out of Motion instead and it seems to work OK. Wouldn't Motion utilize the same Quicktime conversion engine as FCP7?
Weird...
Dave LaRonde
on Jul 31, 2015 at 5:13:22 pm
If you want to check the file, import it into FCP. Put it in a timeline. Render the video. It plays at the timeline's frame rate.
Yeah, it's a pain, but it's Animation-codec footage -- great for alpha channels and preserving image quality, but the wrong thing for playback.
Dave LaRonde
Promotion Producer
Tom Matthies
on Jul 31, 2015 at 9:00:53 pm
59.94 fields per second. I always thought that was just wrong to lost as a frame rate. Actually 29.94 in real life.
Tom Matthies
on Jul 31, 2015 at 9:03:40 pm
List not lost...darn auto correct...
Nick Meyers
on Aug 1, 2015 at 6:33:36 am
i've had weird frames rates from exports in the past,
a solution has been to open the files in Cinema Tools and conform them to the correct frame rate.
nick
Tom Matthies
on Aug 3, 2015 at 10:07:56 pm
Excellent idea! I'll give it a try.
