Editing with different frame rates
Bobby Hall
on Jul 31, 2015 at 6:04:13 am
I want to edit in FCP7 using clips of different frame rates. Some clips are 23.98 and others 29.97. I thought it was a bad idea to mix frame rates in FCP7 because I thought it could potentially make the video out of sync, but I wanted to be sure so I asked an editor about this and he said:
"FCP 7 will render footage which does not match these project settings for frame rate or image size automatically, so there’s nothing you need to do, once you edit a clip into the timeline."
I wanted to get a second opinion about this because I could've sworn I read somewhere it's bad to mix frame rates in FCP7. Can someone tell me if it's okay to mix frame rates in FCP7? Thank you!
Nick Meyers
Re: Editing with different frame rates
on Jul 31, 2015 at 8:16:37 am
the main reason it's bad to do this in FCP7 is that it does such a bad job of handling the difference in frame rates.
i know that for mixing 24 and 25 fps footage it simply adds or deletes a frame every second.
Premiere Pro or Avid are both suposed to do a better job.
nick
