Exporting a 1 hour long file on FCP7
Danny Garcia
on Jul 27, 2015 at 11:38:44 pm
I know 7 is a little out dated but that's what we've been using at the office.
We are exporting a long movie and after 12+ hours I finally got it. However, it won't open on quicktime or anything else. I can play it on VLC but it pauses after 9 mins. I can hit the space bar and it plays for a while on preview but pauses just the same.
I am exporting again, this time instead of h264 im doing apple proress 422 and I only have 22 hours remaining.
I was wondering if this is a common factor in exporting long video files? Any advice would be greatly appreciated.
What steps or hoops should i be aware of?
thanks
David Roth Weiss
Re: Exporting a 1 hour long file on FCP7
on Jul 28, 2015 at 1:53:13 am
Danny,
It's pretty clear from your post that some aspect of your workflow was incorrect. I'd imagine that your inexperience with FCP most likely caused you to start the project incorrectly, which is the most common issue when starting out with the application.
In order to help you more info is required. The most basic info necessary to help you with any precision is:
1) What media type (codec) are you editing? If you don't know, what type of camera was used, and did you transcode that prior to editing, or are you editing native files?
2) What are your sequence settings? (Posting a screen grab would help)
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Danny Garcia
on Jul 28, 2015 at 4:59:53 am
David,
actually, it is a reel from various different video makers with different techniques. so that might be what is bugging the export?
Should I compress all of them and throw them back on the timeline?
What would be an ideal sequence setting for combining mixed media formats?
David Roth Weiss
on Jul 28, 2015 at 6:25:38 am
Your best bet in this case would be to transcode all files to a single "mezzanine codec," and I would recommend Pro Res 422. It's a high-performance codec, meaning faster renders. If you were mixing material before, especially if you were editing h.264 or mpeg4, those are not really file types supported in FCP 7, even though they seem to work, albeit extremely slowly and often with many other issues.
David Roth Weiss
Nick Meyers
on Jul 28, 2015 at 12:10:28 pm
getting the majority of your media to match your sequence settings is important in FCP7
so unless you have added a lot of fx, then the majority of your timeline should not need rendering.
if it does then you're doing something wrong, and you have to stop and figure out what that is
if you HAVE a lot of fx, or even if you haven't,
its always smart to FULLY RENDER your entire timeline.
this means going to the Sequence Menu > Render All, and ticking "Full",
and hitting Option R when you want to render
once you've fully rendered, the export will be much faster,
and of course when you have to change one little part, you just re-render that bit,
and are ready for another fast-as-possible render.
nick
