HD Pal to NTSC
Chico Dall'Inha
HD Pal to NTSC
on Jul 23, 2015 at 5:39:12 pm
Hi Everyone,
I wonder if anyone could help me.
I have a final HD edited video in 1080p 25fps that needs to be converted to 1080p 30fps for USA.
I need to make a SD DVD in NTSC. Any suggestions on how to proceed?
I have never done any conversion from Pal to NTSC before.
Many Thanks
Chico Dall'Inha
Chico Dall'Inha
Director, Producer & Editor
Shane Ross
Re: HD Pal to NTSC
on Jul 23, 2015 at 7:05:15 pm
What's your budget? because the best way is a hardware converter...Terranex. And if it's a file, they'll need to play out from one computer and capture in another.
Can try Compressor, export a small chunk, the one with the most movement. Change the frame rate, turn on the FRAME CONTROLS and set everything to BEST.
Still, this won't be smooth. 24p to 30p is not a good conversion, so 25p to 30p won't really be either. No way to spread out the repeated frames amongst fields. 25p to 30i would be the best way. Might try that. Even though it's 30i...it'll still look progressive. This is how films shot at 24fps are telecined to 30i tape, and shown on TV, that broadcasts at 30i...3:2 pulldown. Might get trickier with PAL...25fps.
Shane
Little Frog Post
