Audio Mixing Surface for FCP7
David Page
on Jul 17, 2015 at 7:54:56 pm
Can someone please recommend a moderately priced audio control surface that works well with FCP 7?
Nick Meyers
Re: Audio Mixing Surface for FCP7
on Jul 18, 2015 at 4:52:02 pm
i had a Behringer BCF2000.
very simple, and affordable.
i wound up not using it that much.
the plastic faders made horrible clacking sounds when in automation.
check it out here:
i wound up using an Alpha-track single fader control surface,
which was great,
i mainly needed to ride levels on music and atmos tracks,
dialogue and spot effects, i use keyboard shortcuts for.
i dont think either are available other than on e-bay,
but Behringer does have a nicely priced unit called X-Control compact
touch sensitive faders, which the old one didn't have
i;d check it out before you buy it though, see if the faders are still just a noisy as the old one.
nick
Warren Eig
on Jul 18, 2015 at 6:22:23 pm
I use the Mackie MCU with extended faders.
http://www.mackie.com/products/mcupro/index.html
It work great and I've programmed the job / shuttle wheel and other buttons to mark in/out, play etc.
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.BabyBoomPictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Shane Ross
on Jul 18, 2015 at 9:42:22 pm
I had a mixer that also did this...forget the model. But didn't use it also because it was noisy. Fwoosh...swoosh...swish...swush....whoosh... All....THE....TIME.
Shane
Little Frog Post
Nick Meyers
on Jul 19, 2015 at 12:20:53 am
the Alpha track had a dial to select tracks.
so in a pinch you could almost work 2 tracks at once,
but the best thing about that dial was i'd just spin it all the way up to select a track with nothing, or next to nothing on it.
no more shoosh, shoosh
nick
Nick Meyers
on Jul 19, 2015 at 12:44:49 pm
not a recommendation, but the Korg NanoKontrol2 looks cool.
Mark Suszko
on Jul 20, 2015 at 6:19:23 pm
There are now iPad apps that can do this.
