FCP7 and operating systems
Wendy Rowland
on Jul 17, 2015 at 1:39:15 pm
I am still using FCP7 and after it was discontinued by Apple I immediately stopped upgrading my operating system and am still editing with 10.6.8. I have a macbook pro that I would like to be able to use with FCP7 on the road (OSX 10.9.5). I'm wondering about installing FCP7 onto an external drive (Lacie D2 quadra) and running it like that (rather than installing FCP7 onto the actual harddrive of the computer. I wonder if anyone has any advice - will this work? Is this the best approach? I have heard that newer operating systems no longer support FCP7 and maybe I should grit my teeth and abandon it ... but I am putting it off for as long as possible.
Thanks in advance for any suggestions!
Warren Eig
Re: FCP7 and operating systems
on Jul 17, 2015 at 3:36:29 pm
There will come a day when it won't be supported. Right now it works fine in 10.10.4 with a Kona 4 card to 48TB shared storage.
On your main system if it works as is don't upgrade, I had to to run AVID and FCP X so I upgraded but I still have a hard drive cloned with an earlier system in case there was a problem. Try an external drive with 10.10.4 and FCP7 for your laptop. Put it through its paces. See if it works for you.
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.BabyBoomPictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Wendy Rowland
on Jul 17, 2015 at 3:56:24 pm
Thanks for this Warren. Apologies for my ignorance but do I have to have a Kona Card? I was hoping to just put FCP7 on my 5 TB D2 Quadra Lacie Drive and my footage would also be on this drive. The files are not huge and it is simple talking heads interviews that I am editing (short 10 minute videos).
And yes, I agree with you about my main system. It still works fine so I'm not messing with it. Soon I am going to make the switch (probably to Adobe Premiere) but for now I am in avoidance mode.
Warren Eig
on Jul 17, 2015 at 4:19:51 pm
No you don't need the Kona card. I was just stating how my system is set up and all is working. Of course if you want accurate images to color correct, view etc., then a Kona card for a PCIe equipped machine or AJA's 4K thunderbolt unit for a Macbook Pro is a must ;)
Warren Eig
O 310-470-0905
Mark Suszko
on Jul 17, 2015 at 4:46:31 pm
Wendy, you should look at this as a chance to start bridging to a new platform: simple talking head interviews are super-fast to edit in FCPX. This will get your feet wet in FCPX, while you continue to work with the older gear on the side. Just think about it.
Wendy Rowland
on Jul 17, 2015 at 4:49:15 pm
I know Mark you are TOTALLY right about this ... but I have dipped my toe into FCPX and do not like it at all. It doesn't seem intuitive. I'm leaning towards Adobe Premiere for this reason but perhaps I should try FCPX again ... I just have too much trouble letting go of FCP7!
Wendy R
Shane Ross
on Jul 17, 2015 at 5:59:34 pm
Before you do ANY upgrading...clone your working OS drive. Make a direct copy. Carbon Copy Cloner does this.
FCP 7 stopped being supported at 10.7...but it works fine, fully, under 10.8. Some issues with 10.9 (Compressor and Motion no longer work...people report exporting issues)...and it just gets worse with every upgrade after that. It might work fine for Warren under 10.10...but many many issues of people going "this used to work, but now that I'm in 10.10, it doesn't" pop up here and on many forums. Some things work for some people, some don't.
So clone...and if things don't work, you can go back. OR...you can install the OS on a second drive. Or clone, partition your drive into two, clone back to one of the partitions, update OS to 10.10 on the other.
Shane
Little Frog Post
Nick Meyers
on Jul 18, 2015 at 4:57:26 pm
i wouldn't mind seeing a list of what does and doesn't work.
for me the bigest problem is that the eye-dropper colour pickers in the various generators don't work.
you can click open the colour pane, and use the eye dropper in that.
but that option isn't available in the Colour Correction filters, so matching shots has do be done manually.
nick
