Spinning Pinwheel Every Time I Switch Applications Back to FCP7?
Stephen Metzger
on Jul 9, 2015 at 6:46:42 pm
I'm editing a project on FCP7, and every time I switch back to FCP from any other application, I get a stopwatch for a few seconds and then a spinning pinwheel for about 10 seconds.
Does anyone know why this would be happening and if there's something I can do about it?
I'm on an early 2013 MacBook Pro running OS X Yosemite and editing with a USB 3.0 drive using mainly DVCPRO HD footage (lots of it.). Never had this problem with other projects.
Thanks.
Shane Ross
Re: Spinning Pinwheel Every Time I Switch Applications Back to FCP7?
on Jul 9, 2015 at 7:12:46 pm
[Stephen Metzger] "I'm on an early 2013 MacBook Pro running OS X Yosemite"
That's why. FCP 7 isn't supported under Yosemite. Full support for FCP 7 stopped at 10.8...actually, I think before that. 10.7 was in play when FCP 7 was discontinued, and no longer supported by Apple. OS 10.8 worked fine...but really, from that point on they didn't take FCP 7 compatibility into consideration when making later OS versions.
Shane
Little Frog Post
Tom Matthies
on Jul 9, 2015 at 8:16:26 pm
You might check your Power preferences and make sure that your external drive isn't spinning down or going to sleep while you are using a different application. It sounds like FCP might be waiting for the drive to spin back up before it responds.
Not my monkeys. Not my circus.
