mixing 1440 with 1920
Rob Gutermuth
on Jun 29, 2015 at 1:54:16 pm
Hi All,
So I have a few multi cam shoots where 2 of the cameras are HD 1920x1080i and 2 are HDV 1440x1080i
what is the best way to go, so that they are all the same in the timeline?
Option 1:
choose a 1920x1080 sequence which is native to 2 cameras, but the other 2 would have to be zoomed to like 137 percent or something to conform
Option 2:
Choose a 1440x1080 sequence, native to the HDV frame size, and then the aspect settings for the 1920 footage has to change to allow them to conform....
I'm using option 2 right now, since that seems to look better than option 1, but is there a good option 3?
Thanks all
Rob Gutermuth
Media Creations
Mark Suszko
Re: mixing 1440 with 1920
on Jun 29, 2015 at 4:02:20 pm
Yes, buy cameras that match next time:-) But your choice of option 2 is what most people do.
Rob Gutermuth
on Jun 29, 2015 at 4:37:15 pm
Buy cameras that match.... lol. Yeah, that would be the best solution... but my money tree isn't giving me anything lately :-)
I just read on here that 1440x1080i HDV is really 1920 anyways... True or not... some say yes, some say no... so, which is it?
The seq didn't have to re-render when I used Prores as the codec for the sequence (native clips, etc) - but the export takes 10x longer, and the file size is of course a lot bigger... and also it choose Square for the pixels.... HDV didn't use that... does that matter?
I guess my question is...
would it be better to use the native 1440x1080i 60 HDV settings for the sequence, which matches perfectly with the main 2 cameras, and then force render the other 2, to I guess down convert from prores 1920x1080i 60
or, just have the HDV footage in a prores sequence... what should all the setting be then, if I do that?
not that it matters, but all cameras are set to NDF. My end result will be DVD mostly.
Rob Gutermuth
Media Creations
Michael Gissing
on Jun 30, 2015 at 4:56:56 am
My advice is to chose option one. 1920 x 1080 is a proper frame standard and when you drop HDV 1440 in FCP automatically applies a 33.3% distort (not zoom).
A 1440 x 1080 timeline means the 1920 gets squished and then on output everything stretched. Option one is correct and will require the least rendering.
Daryl K Davis
on Jun 30, 2015 at 3:12:42 pm
Yes, go full raster 1920 x 1080. You will not regret it.
DK Davis / Editor/ Post Super
