? regarding "a real-time preset to match broadcast specifications (Rec. 709)."
keith mann
on Jun 18, 2015 at 11:18:04 pm
FCX 10.2 features" "a real-time preset to adjust the look of the image to match broadcast specifications (Rec. 709)."
Does this mean:
By "look" do they mean the program is in Rec 709 color space? Or is it still log and just adjusted to look like Rec 709?
Is the FCX window simulating the look of what Rec 709 would look like on a broadcast monitor, so we do not "need" a second HDTV to color correct? Or are we still seeing log in the FCX window?
Is rec 709 output from the thunderbolt / displayport so we can use a cheap displayport - to - HDMI adaptor to see rec 709 on a connected HDTV? Or do we still have to put a converter box downstream of the displayport?
Does using the preset mean export is in Rec 709? All the time, for ProRes and mp4?
Are there any downsides to using Rec 709 for web only distirbution?
Thanks in advance
Michael Gissing
Re: ? regarding "a real-time preset to match broadcast specifications (Rec. 709)."
on Jun 18, 2015 at 11:49:54 pm
You might want to ask here -
https://forums.creativecow.net/fcpxtechnique
This forum is for FCP7 or Legend as we like to call it.
keith mann
on Jun 19, 2015 at 4:28:32 am
Opps. Thank you, will repost correctly.
